Can someone speak to the performance verification check on mid year vent window regulators? I'm in process of rebuilding mine now and plan to use the machined aluminum gears sold by AFC. Due to the complexity of the original configuration of the pot metal gear, this kit is supplied with a thick washer that eliminates the crank stops that are part of the original gear's configuration.
Would the absence of a "stop" when opening the vent window be considered a failure during PV?
I've devised a way to regain the "stop" feature for the crank gear and am considering writing an article for the "Restorer" but I'd like to know if this is even a problem before I go to the trouble.
tc
tc
