Double clicking sound on acceleration and deacceleration - NCRS Discussion Boards
+ More Options
Posts
  • Roger G.
    • October 11, 2012
    • 268
    What are possible causes of a double clicking sound heard on hard acceleration and deacceleration? This is a metallic sound, almost like a clock ticking. There are two distinct clicks heard both when accelerating and deaccelerating It is hard to localize where it is coming from. The car is a 69 427/400 4 speed with side pipes. I initially thought it was from the side pipe, but could be rearend, or even clutch or transmission, doesnt seem to be coming from the motor, but maybe it is being transmitted through the exhaust. Thanks
  • Jack C.
    • September 30, 1992
    • 1090
    Re: Double clicking sound on acceleration and deacceleration
    Did you take a look at the rear differential carrier mounting cushion? Paragon 5751K
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Donald O.
      • May 31, 1990
      • 1593
      Check your drive shaft and axle u-joints. Check your front Diff. or pinion bushes. Check your rear axle bearings.
