1960 coil wire orientation? - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2593
    I've looked in the AIM, searched this forum and looked in the ST-12. I've probably overlooked it, but which wire goes to which terminal on the Coil. I assume the black wire from the distributor goes to the '+' positive terminal and the green wire from the balast resistor goes to the '-' negative terminal. Is this correct?
    I actually found a picture in a thread that showed both wires on the positive terminal, so which is correct?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11366
    Re: 1960 coil wire orientation?
    Don,
    It's in the wiring diagram......http://www.keystonestatecorvetteclub...tte%201960.pdf
    Green to coil +
    Black to coil -
    Rich
    • Donald H.
      • November 2, 2009
      • 2593
      Don,
      It's in the wiring diagram......http://www.keystonestatecorvetteclub...vette 1960.pdf
      Green to coil +
      Black to coil -
      Rich
      Now how logical is that, the one place I didn't but should have looked. I looked in Section 12, but didn't look at the wiring diagram.
      Don
      Don Harris
