I posted a question on battery drain a few months ago. One was solved with a better battery as many suggested. Seems like the shut down time for the computers exceeded the battery capacity. Car now can sit with no further problems. The other one, a '01 3/4 Chevy truck, is still having a problem with battery drain. A blade disconnect works well for now. I did some research and found that I may have not let the car sit long enough with a shunt in place for all the systems to close and therefor hindered my search. I was also told to pull one fuse at a time AND NOT REPLACE IT until I found the troubled component.
Update on battery drain.
Re: Update on battery drain.
That's good old fashioned shadetree troubleshooting. It can give you the circuit where the problem is. Unfortunately, you will still have to trace the circuit to find the issue. Don't forget the basics, that most battery drain issues are caused by voltage regulators and shorts. If you have'nt done this already, you might want to Google "2001 Chevy truck battery drain" and go into the forums that come up. It might point you in the right direction.
Paul- Top
open the glove box and feel the bulb right away. if it is already hot you have found your problem. on my 88 silverado i had to add a piece of rubber tubing to the plunger as it was too short to get the light to go out- Top
How did you determine the 8 watt draw? Should be expressed in amps. Most vehicles with computers and modern electronics pull a small amperage when off, but that should be fairly small 50-100 ma. If it is much more than that, you should go looking.- Top
Had a battery drain on a 2001 chev and it was the body control module. I could pull the fuse from the offending circuit after shutting the car down and it would restart fine. Got a BCM from GM direct but the dealer had to burn the chip.- Top
Thats way too much for sure. 700 ma will kill a new battery in just a few days.
I would look at circuits with major items that stay on when the key is off. First and foremost would be the alternator itself.- Top
Paul- Top
