Steering Stabilizer Shock - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7018
    https://dansshocks.com/
    Gary
    • Gerald C.
      • June 30, 1987
      • 1283
      Re: Steering Stabilizer Shock
      Thanks Gary
      • Larry E.
        • 1677
        #18
        FWIW> If your C2 has Manual Steering and Side Pipes this Stabilizer Shock WILL COME
        CLOSE to the exhaust pipes. (See Picture Below) I realize that all cars made do have a
        slightly difference tolerance so your car MAY have a bit more clearance. But not a lot
        difference. If the car is used a lot THIS will damage the shock in due time. I use a exhaust pipe wrap
        (Bought at Summit Racing) to protect the shock. It is easily removed for judging purposes.
        JMHO>Larry
        Larry
        LT1 in a 1LE -- One of 134
        • Gary B.
          • February 1, 1997
          • 7018
          #19
          Larry,
          Does the wrap you use have adhesive on one side and you install it like tape?
          Gary
          • Larry E.
            • 1677
            #20
            Originally posted by Gary Beaupre (28818)
            Larry,
            Gary
            Hay Gary: No Tape involve. See Below. Works Great. Larry
            Thermo-Tec Clamp-On Pipe Heat Shields 11620
            Exhaust Wrap, Pipe Heat Shield, Thermo-Tec, Silver, 6 in. Wide x 24 in., 3 in. Clamps, Each
            Part Number: THE-11620
            4.57 out of 5 stars ( 7
            Larry
            • Gary B.
              • February 1, 1997
              • 7018
              #21
              • Larry E.
                • 1677
                #22
                Gary: Can't remember if I used the 1' or 2'. I know it extended well past that shock bracket. Thinking either
                one would be OK. Larry P.S. Also traded out the 5" clamps to 4" ones.
                Larry
                • Gary B.
                  • February 1, 1997
                  • 7018
                  #23
                  Larry,
                  Thanks.
                  Gary
                  • Gerald C.
                    • June 30, 1987
                    • 1283
                    #24
                    Does anyone know where I can buy the bushing set for my 1963 non-power Steering Stabilizer shock? It functions fine but the bushings are a little "tired". One of the bushings has the bolt coming out of it.
                    Thanks for the feedback.
