66 fuel pump - NCRS Discussion Boards
66 fuel pump
  • Morris R.
    • May 7, 2012
    • 213
    66 fuel pump
    What is correct for a 66 corvette 327/350hp fuel pump # 40083 one with the cast metal on the bottom with ac marked or a flat metal one without the ac logo or both? Thank you
  • Donald H.
    • November 2, 2009
    • 2586
    Re: 66 fuel pump
    According to the 66 TIM & JG it is the one with the stamped steel cadmium dichromate plated bottom. I've been looking for one for a while and had a thread earlier if you check the link below
    https://www.forums.ncrs.org/showthre...-Will-the-work
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
    • David L.
      • July 31, 1980
      • 3310
      Re: 66 fuel pump
      I have an original 1966 Nova w/L79 AC fuel pump stamped "40394" with a stamped steel bottom (photos in the link in Don's post). The angle between the inlet and outlet of a "40394" pump is 108 degrees while the angle between the inlet and outlet on a "40083" pump is 180 degrees.
      Dave
      • Morris R.
        • May 7, 2012
        • 213
        Re: 66 fuel pump
        Sorry dave can't use it thank you
        • David L.
          • July 31, 1980
          • 3310
          Re: 66 fuel pump
          Morris,
          The fuel pump is not for sale. I was just posting information to verify that this style of pump had a stamped steel bottom in 1966. I bought the pump at a swap meet earlier this Fall in Connecticut for $5. After researching the web it's a very rare original AC fuel pump for a 1966 Nova w/L79.
          Dave
