Parts help please!! - NCRS Discussion Boards
Parts help please!!
  • Donald H.
    • November 2, 2009
    • 2580
    Parts help please!!
    I'm trying to identify the Fan Blade Spacer that come off my 1960. It has the part number 3857041 casting and and N D cast above the part number. I'm trying to find out if it is the correct overall length for my 1960. The correct spacer per the 1960 AIM is 3754905.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Joe M.
    • April 30, 1990
    • 1338
    Re: Parts help please!!
    Donald, Noland Adam's book states that the spacer moved the fan assembly 1-15/16" closer to the radiator and that matches the length of my spacer. Adams confirms the spacer part number in the AIM.
    • Donald H.
      • November 2, 2009
      • 2580
      Hopefully someone can tell me what I have and what it goes to.
      Don Harris
      • Tom D.
        • September 30, 1981
        • 2134
        Other discussion still "live" at https://www.forums.ncrs.org/showthre...mounting-bolts
        https://MichiganNCRS.org
        Michigan Chapter
        Tom Dingman
        • Donald H.
          • November 2, 2009
          • 2580
          Originally posted by Tom Dingman (4889)
          I only started another thread because I did not think anyone would be looking to identify a part with a title about bolts.
          Don Harris
          • Robert E.
            • April 1, 2004
            • 398
            See http://www.gmpartswiki.com/w/3857041&book=167
            Robert
            • Donald H.
              • November 2, 2009
              • 2580
              I think I answered my own question. Looks like it is for 67, 68, 69 Camero SS 350 and 67, 68 Impala 396/427. Or at least that is what one is listed for on Ebay.
              Don
              Don Harris
                • 43221
                Don
                Don-----
                GM #3857041 was used for many Chevrolet applications over the 1960 to 1968 period but no Corvette applications. It was used for 1967-68 Camaros without fan clutch but it was not used for 1969 Camaros. The 3757041 was 2-1/8" OD and 1-45/64" thick. It was discontinued without supercession in 1983. The 3754905 which was used on Corvettes was 2-3/8" OD and 1-15/16" thick. It was discontinued in November, 1962 and replaced by GM #3814241. The latter was discontinued without supercession in 1984.
                • Donald H.
                  • November 2, 2009
                  • 2580
                  Thanks Joe
                  Don Harris
                  • David L.
                    • July 31, 1980
                    • 3310
                    Don,
                    I have 4 fan spacers in my "collection" that measure 2 3/8" O.D. and 1.90" to 1.92" long. The one from the 1959 Chevrolet 283 (May 1959) must be GM # 3754905 and the other 3 must be GM # 3814241 as per my 1963 and 1964 Chevrolet Parts Catalogs. They are basically all the same except for weight (weights shown are approx. using a baby scale).
                    There must have been 2 vendors for the 3814241 spacers.
                    59 Chev. 283, 6 oz., 1.92"
                    63 Chev. 283, 12 oz., 1.90"
                    64 Chev. 283, 4 oz., 1.91"
                    unlabeled, 4 oz., 1.91"
                    I sold my 1955, 1956, 1958, 1959, 1960, 1961, and 1962 Chev. parts catalogs several years ago.
                    Dave
                    • David L.
                      • July 31, 1980
                      • 3310
                      Don,
                      I just found another spacer (not labeled) that measures 1.90" long and weighs 6 oz. It must be GM # 3754905 because of the weight. It has four 5/16" fine thread bolts that measure 2 3/4" long (effective length) with 1" thread length and "UR" & 8 radial markings. I must have lost 2 of the lock washers.
                      Dave
                      • Donald H.
                        • November 2, 2009
                        • 2580
                        Originally posted by David Liukkonen (3775)
                        Don,
                        Dave
                        Dave,
                        You didn't mention if you found the part number on the spacers? Here are pictures of a correct one for 1960 per my AIM, part number 3754905 (I just bought off Ebay), and the one that came off my 60 vette, part number 3857401. The UR headmarkings agree with findings in the 1958-60 Corvette Restoration Handbook.
                        Don
                        Don Harris
                        • David L.
                          • July 31, 1980
                          • 3310
                          Don,
                          None of my 5 original production line spacers (1 3/4" bolt circle) have a part number on them. There must have been more then one vendor that made the spacers for GM. I also have several original fan spacers (2 1/8" bolt circle) for 1969 & newer Chev. models and they all have parts numbers, some of which also have "N.M.P" while others do not indicating different vendors or made at different times or different molds.
                          I have more fan bolts in a box marked "5/16" eng. bolts" in my garage. When I get a chance I will check.
                          Dave
                            • 43221
                            Dave,
                            Don
                            [ATTACH=CONFIG]43398[/ATTACH][ATTACH=CONFIG]43397[/ATTACH]
                            Don-----
                            What is the thickness of the 3754905 spacer you have?
