'68 Wiring Questons - NCRS Discussion Boards
'68 Wiring Questons
  • Brian W.
    • September 30, 1990
    • 216
    '68 Wiring Questons
    Mid December '67 car - wiper motor wiring. I have a blue & yellow wire with push-in plugs. Does the yellow or blue go on the right side when facing the motor?
    Does the ground wire for the horn relay go on the mounting stud? Thanks
    Brian
  • John C.
    • January 1, 2005
    • 616
    Re: '68 Wiring Questons
    Brian
    It is a mess of wires, hoses, ignition shielding and dirt in that area. I took a couple pictures that I hope show you what you need to know.
    John
    • Brian W.
      • 216
      Thank's John
      • Jim T.
        • March 1, 1993
        • 5351
        The two wires you have in question connect to the actual windshield pumper/washer function correct? The original untouched wiring in my 68 original owner convertible has the yellow wire plugged in on the right and the blue wire is plugged in on the left for the windshield washer pumper.
        The ground wire is connected to the mounting bolt/stud of the relay.
        • Terry B.
          • August 31, 1999
          • 607
          Brian,
          This link from Willcox may help you too. http://www.youtube.com/watch?v=XpkbC...ayer_embedded#!
          Terry Buchanan
          Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
          Corvettes Owned:
          1977 Coupe
          1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
          2003 Electron Blue Coupe
          2019 Torch Red Grand Sport Coupe
