I have a 1966 coupe w/L79 engine. Recently the engine has been shutting down while being driven for aparantly no reason. All it takes to start the engine again is to depress the clutch and restart the engine. I have had some issues in the past with the bulkhead connector but that usually killed all electrical power to the fuse block. i.e. nothing electrical worked. All that was needed was to jiggle the connector. I also had an issue with one electrical connection on the ignition switch which caused accessories i.e. cigarette lighteer, clock, interior lights, radio, etc. to cease operating but not the engine.
Do these symptoms indicate an engine harness replacement, a bulkhead connector replacement, a fuse block repair kit or some other repair kit?
Any help would be appreciated.
