Harmonic balancer installation question - NCRS Discussion Boards
  • Bruce B.
    • May 31, 1996
    • 2930
    When installing a balancer using the correct tool should any lubrication (oil, grease) be used on the mating surfaces?
    After installation a safety bolt and washer will be installed into the crankshaft.
    • 43281
    Re: Harmonic balancer installation question
    Bruce-----
    DEFINITELY use lubrication. I use a very light coating of EP chassis lube.
    By the way, make absolutely certain that there exist no "burrs" or "dings" on either the crankshaft snout or the balancer orifice. If there is you'll have a rough go of it trying to install the balancer and you'll likely break the installation tool or strip out its threads or the threads in the crankshaft.
    • Bruce B.
      • May 31, 1996
      • 2930
      Joe,
      Thanks.
      • Ray G.
        • May 31, 1986
        • 1189
        Hello Bruce;
        Additionally;
        We use a light coating, of your choice, of sealer.
        There is a remote chance of oil seeping out through the keyway slot.
        Hope this helps.
        Ray
        I hope you dance
        • Bruce B.
          • May 31, 1996
          • 2930
          Thanks guys.
