C3 Valve covers - NCRS Discussion Boards
C3 Valve covers
  • Peter S.
    • March 28, 2012
    • 327
    C3 Valve covers
    Gents,
    Where there any differences (besides the dripper-less '69s) in the L46/LT-1/L82 valve covers? From an NCRS standpoint, would one be able to distinguish between a set of 1969 L46 valve covers vs. a 1975 L82 valve covers?
    Peter
  • Michael D.
    • June 30, 1996
    • 536
    Re: C3 Valve covers
    Paint. L-82 valve covers are usually semi-flat black with the tops of the fins unpainted.
    • David L.
      • July 31, 1980
      • 3310
      Re: C3 Valve covers
      Peter,
      I did some research on these valve covers a few years ago and this is what I have found.
      1969 Corvette & Z28: Cast. # "P-3932418"
      Without drippers, "cutouts" are 3" long
      1970 Corvette & Z28: Cast # "P-3932417-LH", "P-3965543-LH", "P-3965544-RH"
      Drippers are 11/16" wide @ bottom, 3/4" in height, "cutouts" are 3" long
      These covers were possibly used on very late 69 Z28's made in Oct. & Nov. 1969.
      1971-1972 Corvette & Z28: Cast. # "3989005 L.H.", "3965542 R.H."
      Oil cap hole is round for black rubber oil cap, "cutouts" are 3" long
      1973-1977 Corvette & 1973-1974 Z28: Cast. # "P 3965543 LH CBC", "P 3965544 RH'
      Drippers are 5/8" wide, 5/8" in height, "cutouts" are 3 9/16" and 5" long
      Dave
      • Peter S.
        • March 28, 2012
        • 327
        Re: C3 Valve covers
        Hi Michael,
        The L-82 valve covers on the '75 were left as-cast aluminum.
        Originally posted by David Liukkonen (3775)
        Peter,
        Dave
        Good info David. Can you define what you mean by "cutouts"?
        • Russ S.
          • April 30, 1982
          • 2163
          Re: C3 Valve covers
          Only the newer years have paint. 73,74,75 and possibly later didn't have paint.
          • David L.
            • July 31, 1980
            • 3310
            Re: C3 Valve covers
            The "cutouts" are long thin notches along the edge of the valve cover on the intake side for clearance purposes. On the 69-72 covers there are 2 "cutouts" about 3" long by about 1/8" (or maybe 1/4") or so as best as I can remember.
            • Steven B.
              • June 30, 1982
              • 4009
              Re: C3 Valve covers
              '77 and older no paint,
              • Peter S.
                • March 28, 2012
                • 327
                Re: C3 Valve covers
