61 coil bracket - NCRS Discussion Boards
61 coil bracket
  • Robert B.
    • February 29, 1992
    • 263
    61 coil bracket
    The oiler on the 270 HP distributor is preventing me from installing the bracket for my coil because it is hitting it. I am thinking that the timing my be off a tooth. anybody know what I am talking about ?
  • John F.
    • March 23, 2008
    • 2395
    Re: 61 coil bracket
    It is a tight fit on my 62s!
    • William C.
      • May 31, 1975
      • 6037
      Re: 61 coil bracket
      Assuming all the parts are correct, There is a specific location the distributor is in as delivered to the assembly plant, and that will locate the clips for the cap on an axis parallel to the centerline of the engine. Look at the AIM Section 6, sheet 12 (at least in my '62 AIM, or look for a similar page in the '61 aim. Align the distributor properly so the rotor points to the proper location to fire #1 when the balancer indicates timing is correct, and you should clear the brackets easily.
      Bill Clupper #618
      • Robert B.
        • February 29, 1992
        • 263
        Re: 61 coil bracket
        right on thanks
