1957 Steering column - NCRS Discussion Boards
  • John P.
    • January 1, 2006
    • 163
    Hello, I looked at a 1957 Corvette, Cascade green with beige interior for a friend to purchase. The car is origional with the only body repairs made to the right rear from an impact. My question is the lower portion of the steering column (below dash) is painted the same color as the body (cascade green). It appears to have never been repaired or painted, and is in the same condition as the remainder of the car. I know that the technical manual states the color should be the same as the lower dash panel (beige), however I cannot see that this has ever been painted. Is it possible that some of these were painted the exterior color? This is an april 1957 built unit if it makes any difference. As always, thank you for any and all help. John
  • Jerry B.
    • August 31, 1994
    • 416
    Re: 1957 Steering column
    When stripping none original red paint from the column on my 57, it was painted shoreline beige from the hub to the sterring box from the factory. Take a look under your steering culumn mounting support as I did, it was shoreline.
