1967 400 hp. Fuel Pump - NCRS Discussion Boards
  • Michael S.
    • 68
    Does any have a photo they can post of an original assembly line correct 400 hp. fuel pump that would have been used at the end of November 1966?
    Mike
    Re: 1967 400 hp. Fuel Pump
    Mike
    Mike -
    The 40482 pump looks like those in the photo below.
    • David L.
      • July 31, 1980
      • 3310
      Mike,
      According to the 1967 AIM fuel pump # 6440482 (AC 40482) was used on L36 and L68 engines.
      NOTE: UPC L36, sheet A8, was redrawn on 11-9-66. Also see UPC L71 L68, sheet A2.
      GM # 6416741 = AC # 40482
      There is a NOS 6416741 fuel pump currently on Ebay (auction # 310522378052, not mine) that is stamped "CG 40482" (March 1967) with a starting bid of $399 and with 10 photos. The AC box is mid to late 1960's vintage. The date code is a bit too late for your car but I would think that it would be the same as one made in November 1966 or prior.
      Dave
      • Michael S.
        • 68
        John and David,
        Thanks for your help. That is exactly what I needed.
        If CG is March of 67, what should the date code be for September or October of 66?
        Mike
        • David L.
          • July 31, 1980
          • 3310
          Mike,
          A Sept. 1966 pump would be stamped "IF 40482" and a Oct. 1966 pump would be stamped "JF 40482". The letter "I" was used. I did some research of stamped date codes on AC fuel pumps as shown in the link below.
          Dave
          https://www.forums.ncrs.org/showthre...380#post540380
          • Michael S.
            • 68
            Dave,
            Thanks for the information on the dates. It never ceases to amaze me about the use of the letter "I".
            Thanks again,
            Mike
              Dave,
              Thanks again,
              Mike
              Mike -
              A good general rule for the letter "I" is this - if it's a raised character on a casting, "I" was used; if it's a STAMPED character on a sheet metal part, "I" wasn't used.
              • Keith B.
                • December 1, 1991
                • 397
                Here is a picture of an original fuel pump. please note the difference in the bottom of the pump.IMG_2534.jpgIMG_2535.jpg
                Keith Burmeister
                • David L.
                  • July 31, 1980
                  • 3310
                  Keith,
                  What is the actual stamped number on your original pump? The NOS "CG 40482" pump (which I believe is dated March 1967) on Ebay # 310522378052 definitely is different.
                  Dave
                  • Michael S.
                    • 68
                    Dave,
                    It looks like "HF" to me from Keith's photo. This would be Aug. of 66?
                    Mike
                    • Michael S.
                      • 68
                      Keith,
                      Are these pumps rebuildable and is this one for sale?
                      Mike
                      • David L.
                        • July 31, 1980
                        • 3310
                        Dave,
                        Mike
                        Mike,
                        After looking at the photo again the stamping is "HF 40482" where "HF" = August 1966. I guess my old eyes are not working like they used to.
                        There must have been a minor change made sometime between August 1966 and March 1967.
                        Dave
                        • John D.
                          • June 30, 1991
                          • 875
                          FWIW the new AC/Delco service replacements have no markings at all....that's what's on my 67 SB.
                          I have seen recrimped/rebuilt pumps for sale in catalogs but just wasn't comfortable
                          with it...
                          • Michael S.
                            • 68
                              • 43247
                              Originally posted by David Liukkonen (3775)
                              Mike,
                              Dave
                              Dave------
                              There was a change. Generally, the original 1966 pumps have the inlet configuration Keith pictured. I don't know of any source fopr this configuration pump except one originally manufactured this way (i.e. an original or PRODUCTION or SERVICE pump from about the 1966 MY period).
