mid year NOS door window run W/S questions - NCRS Discussion Boards
  • Keith B.
    • March 7, 2008
    • 928
    I saw two pairs in the drive line for NOS coupe window runs for both left and right side doors. how well do they fit compared to current reproductions?
    • 6942
    Re: mid year NOS door window run W/S questions
    Keith I found a couple of NOS ones for my 63. there are no suprises when installing. I have a frenid that used the repro ones and they were a little work installing as they do not have the curve of the channels as the NOS ones did. so that ment bending when installing and riviting.
    • Keith B.
      • March 7, 2008
      • 928
      The ones in the driveline are very pricy. Dad went though at least five sets about fifteen years ago for his 67 coupe until he got some they were decent. I wassent sure if the quality has improved since then.
        • 6942
        Kieth, I brought a new NOS set on E/Bay a couple of years ago for about 90. bucks .My car is a convert. the couple maybe different. as the they wee the front runs only. the rear run is different than the couple.
        • Dale M.
          • December 27, 2007
          • 386
          I assume, You are referring to the window channels for the glass? I just purchase both the front and read for a '64 convertible from a large supplier in Michigan and they fit perfectly. I did have to perform some bending and fitting for the inside and outside wiskers. My car is more of a driver than a "jusged" car. I am not aware of any other differences regarding to judging standardsexcept, the staples I used are SS, but are magnetic. I decided on rust proofing vs original.
          • Stewart L.
            • March 1, 1980
            • 353
            I recently installed an NOS set of window runs in a 67 coupe and they are far superior than any of the repo ones that I have used.
            • Dale M.
              • December 27, 2007
              • 386
              Steward, can you expand on how they were better. I am redoing a '64 and purchase window channels from a major vette supplier and they seem to match prefectly with my originals, except for all the rust. They seems to be as strong, screw holes align up great and the curve matches.
              • Stewart L.
                • March 1, 1980
                • 353
                I assume we are talking about the L shaped window channel that runs up the rear of the window frame and across the top to the vent window. The last set I installed was a couple of years ago so they may be improved since then. The last set of repos I used were too long at the vent window end and had to be trimmed a bit. Also, the retaining prongs on the channel were too big and I had to enlarge the holes in the door to get them to snap into place. Now that they are in they look fine except its hard to get the upper ends to look like originals. Last year I put together a 67 coupe door and the owner had a set OEM's. They snapped in easily and fit good.
                If everything looks good on the repos you have, maybe they have improved them.
                • Dale M.
                  • December 27, 2007
                  • 386
                  I was referrin to the U shape channels that support the front and rear edges of the glass allowing the glass to go up and down. The rear one is a curve shape that bolts to the rear of the door and the front one is supported by a bracket in the lower door and then becomes part of the wind window as this channel is runs along the rear of the wing window. The ones I purchase from Paragon all worked and fit great.
                  Thanks for your information, I value your experience as it changes all the time. Thanks
                    You guys are (inadvertently) talking apples and oranges; the COUPE window glass run is completely different than the CONVERTIBLE window glass run. The coupe part is FAR more sensitive to dimensional accuracy, and nothing works better on a coupe than an original part.
                    • Keith B.
                      • March 7, 2008
                      • 928
                      I know on some one of the NOS parts the quality of the item is not quite what it should be due to the tooling being wore out. Is this the case on the window runs. And yes I am talking about the "U" shaped runs with the fuzzes and steel beed for a coupe
                      • Dale M.
                        • December 27, 2007
                        • 386
                        Thanks, I needed someone with more knowledge to clear this up.
                        • Keith B.
                          • March 7, 2008
                          • 928
                          any more comments on the quality on the NOS window runs
                            Keith -
                            Trivia - I restored a '65 coupe in 1972-3 that had led a VERY hard life, and it needed rear/upper glass channel runs; GM didn't have any at the time, and a check with Chevrolet Purchasing showed the original supplier was USM (United Shoe Machinery Corp.), the manufacturer of Pop-Rivets. I wrote them a letter and enclosed photos of the runs I removed, and they sent me a fresh pair (and a little bag of extra "bubble-clips") at no charge.
                            Did the same thing with Findlay Industries for a set of black leather seat trim covers, but that's another story.
                            • Keith B.
                              • March 7, 2008
                              • 928
                              John so that confirms what I was thinking that they have been out of service for a long time.
