L71 rear main bearing seals and oil pan gaskets - NCRS Discussion Boards
  • Michael J.
    • January 27, 2009
    • 7146
    I am about to tackle that annoying, 3 year old rear main oil leak in my '67. What gaskets and seals are the best for this today? And where can I get them? Thanks.
    • 43249
    Re: L71 rear main bearing seals and oil pan gaskets
    Michael-----
    The best 2 piece rear seal for your application is GM #10117767 or Fel-Pro #2918. Install STRICTLY in accordance with the procedure and diagrams described in the Chevrolet Service Manual. If your crankshaft seal journal is grooved, the only way to stop a leak is with a special "off-set lip" seal.
    The best SEALING oil pan gaskets are the one piece "rubber" type. No such GM gasket is available for your application. The Fel-Pro part number is OS-30061T. However, this gasket is BLUE. If you want a black gasket, I believe one of the other manufacturers (maybe Cometic) has an equivalent gasket in black rubber.
    • Michael J.
      • January 27, 2009
      • 7146
      Thanks Joe!
      • Edward J.
        • September 15, 2008
        • 6950
        Mike a tip to sealing the oil pan gasket, one piece ot other wise. Is to put a dab of permtex gasket maker in the cornors of engine block rear and timing cover front. The one piece gasket will require slightly longer bolts, generally I believe they come with the oil pan gasket set.
        • Clem Z.
          • January 1, 2006
          • 9427
          make sure you use the proper sealant on the rear main cap where it sets against the block. the GM shop manual shows where to use the sealer
          • Michael J.
            • January 27, 2009
            • 7146
            Thanks to all, the parts are on order.
