57 Intake Gaskets - NCRS Discussion Boards
57 Intake Gaskets
  • Jimmy G.
    • November 1, 1979
    • 977
    57 Intake Gaskets
    What is considered the correct NCRS intake to head (i.e.. side gaskets) gaskets for a 57. Is it round tab, square tab, no tab, or a triangle tab??
  • Dave S.
    • August 31, 1992
    • 2930
    Re: 57 Intake Gaskets
    [ATTACH=CONFIG]43066[/ATTACH][ATTACH=CONFIG]43067[/ATTACH]
    Jimmy,
    I have an NOS set from 1957 in the old type paper envelope. I'll check and report back when I get home.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17971
      Jimmy,
      Info is in the '56-7 JM including a photo. Square tab with GM on both the side and end intake gaskets.
      Gary
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Bob J.
        • December 1, 1977
        • 720
        Lower right is my opinion
        • Dave S.
          • August 31, 1992
          • 2930
          Originally posted by Gary Chesnut (5895)
          Jimmy,
          Gary
          Here are photos of my gasket set. GM envelope is dated 1957.
            • 43290
            All-----
            Keep one thing in mind: I believe the "tabs" in question were a means of identifying the manufacturer of a gasket (without removing the manifold). So, it's possible that more than one manufacturer supplied gaskets during any period of time. It could very well be that one manufacturer PREDOMINATED during any period, but that's not to say that others might also have been originally used.
            The most common supplier of these side gaskets to GM for many years was Detroit Gasket (now Corteco). McCord was a close second.
            • Gary C.
              Administrator
              • October 1, 1982
              • 17971
              Dave,
              Neat gasket set. Thanks for sharing.
              Gary
              NCRS Texas Chapter
              • Dave S.
                • August 31, 1992
                • 2930
                Dave,
                Gary
                [ATTACH=CONFIG]43095[/ATTACH]
                Gary,
                Thanks. Not a bad part for a C3 guy. That set was found at a swap meet in NH around 8 years ago. My good friend NCRS #775 found it and I was lucky enough to wrestle it away.
                  • 43290
                  Gary,
                  Dave------
                  The GM #3742241 gasket set was discontinued in August, 1958 and replaced by GM #3752758. Thereafter as follows:
                  GM #3752758>>>> August, 1961 >>>>> GM #3785641
                  GM #3785641>>>> May, 1962>>>>>>>> GM #3819423
                  GM #3819423>>>> December, 1966>>>> GM #3896629
                  GM #3899629>>>> July, 1969>>>>>>>>> GM #3931606
                  GM #3931606>>>> May, 1991>>>>>>>>> discontinued without supercession
