astro vent parts - NCRS Discussion Boards
astro vent parts
  • Ed P.
    • July 31, 2002
    • 270
    astro vent parts
    69 vert the rear astro vent door has a broken part. The plastic cam that the rod goes into that closes the door is snapped off. I cant find this part anywhere. Thanks Ed
  • Jeffrey S.
    • May 31, 1988
    • 1890
    Re: astro vent parts
    Ed,
    Do you still have the broken part? The plastic used for this is most likely ABS which was difficult to repair. Now there are several adhesives available to the public that work well with ABS. One that I have used that works great is called Weld-On made by IPS Corp. Gardena, CA. I purchased it locally here in Detroit at a plastics fabricating company.
    Jeff
    • Ed P.
      • July 31, 2002
      • 270
      yes that is what I will do if I ever find the broken piece. Ed
