Part Numbers- What are they - NCRS Discussion Boards
  • Monte M.
    • January 1, 1991
    • 687
    I have run across a box of NOS parts that is for sale. Most of it is emblems like "454", cross flags, and "Stingray" emblems. From the picture I can tell there are things like fan switches and wiper door switches. I am trying to get the seller to write the part numbers down that cannot be seen in the photo I was sent. There are things like receiver dryer, exhaust brackets, trans cross member mounts, and a ton of small boxes and packages.
    I do have a few of the numbers, but I do not think he will write down the rest. So, I know the emblems are a great find, but would like to know if a few of these other parts are things that people can use. These are spare parts from a 1971, 454 restoration.
    Any help on these few parts would be of help. These are the three part number that were written down.
    GR-9-023 Cush (quite a few of them)
    1-334756
    GR-3.275 Stud (quite a few)
    1-3928905
    GR-10-163 (no clue what it is)
    1-3975371
    There are many more parts, but I do not think I will be getting any more numbers from the seller.
    Thank you
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11360
    Re: Part Numbers- What are they
    Monte,
    Check out this online part number search...
      • 43272
      1-334756
      1-3928905
      1-3975371
      Thank you
      Monte-----
      GM #334756---- 1973-82 body mount cushion for positions 1, 2, 3, and 4
      GM #3928905-----exhaust manifold stud for 68-74 Corvette big blocks with P/S. Installs on left side manifold, forward hole.
      GM #3975371----1970-72 wiper service switch (under dash switch to stop wiper mid travel to replace blade)
      • Kenneth B.
        • August 31, 1984
        • 2091
        Buy a old Corvette parts book. Remember though NOS dose not mean it is exactly like the factory part.
        • Monte M.
          • January 1, 1991
          • 687
          The person selling the parts showed me a few receipts that are in the box. They are all dated from the 80's. So, my guess is most of them are old, but you never know. Plus, the boxes that have tags, the tags on the boxes are the old style tags.
          I do have an original GM parts book.(Black hard cover, white parts number pages, Green diagram pages) Mine is of the 1978 or 1979 era. It does not have a lot of the older part numbers so you can tell what older parts actually are. Where can I get one that goes back to at least 63?
          Joe, can you tell me if the original 1963 headlight bucket wiring harness are the same part number for each side? The small harness that one end plugs into actual headlights, and the other end is a three prong plug that plugs into the main headlight harness.
          And once again,
          A special "THANK YOU" to Joe Lucia for taking the time to provide the service he does for us. Thanks Joe. . . .
            • 43272
            And once again,
            Monte------
            The short connecting harness was the same for both sides.
