66 Blower Motor 30 Amp fuse - NCRS Discussion Boards
  • Gary N.
    • August 31, 1986
    • 118
    I have 66' with AC and the fan blower motor quit. It appears that the 30 amp fuse near the compressor area is blown. How do I open the fuse case? I appears to have two openings on either side of the fuse holder. Does it twist and come apart or do I push in at the small holes and pull the top of the holder straight out. I don't want to break it.
    Gary Nyland
    1966 Black Corvette Air Coupe
    2014 Black Z-51, 3LT Coupe
    1955 Black Chevy Belair Gasser
    1955 Nomad
    • 6950
    Re: 66 Blower Motor 30 Amp fuse
    Gary, if your fuse case is what I think it is, you push it inward and twist.
    • Wayne M.
      • March 1, 1980
      • 6414
      Gary -- (also) check your fusebox on the firewall. I have a note in my '65 AIM that calls for replacing the 10 amp in the fuse receptacle marked "heater" (for non-air cars), with a 30 amp fuse, with air conditioning. Maybe just check what you've got there now. I cannot provide backup to this information --- it doesn't seem to appear in the '65 C60 section.
