1968 Bumper Hardware - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 213
    Is there an easy rule that all bumper washers are zinc? If a bolt is phosphate, is the lock washer also? Thanks for your expertise.
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
  • Gary B.
    • February 1, 1997
    • 7064
    Re: 1968 Bumper Hardware
    William,
    Based on my research, the bumper-related lock washer that was used in 1966, GM # 103328 (I'm guessing this was still used in '68, but you can confirm this by looking at the '68 AIM, if you have one) was plain or black phosphate, not zinc/cad. [As an aside, I believe all 103xxx lock washers were plain or black phosphate. Washers that were zinc/cad would have had a part number not starting with 103.) For '66, lock washer 103328 was used at all bumper bolt locations, which means it was used with zinc (or cad) bolts (which were used at all but 4 bumper brace/attachment locations), and that same lock washer was used at the front center brace location, which were a total of four black phosphate bolts & nuts in '66. So, there could not have been a rule that the lock washer had the same finish/plating as the bolt/nut it was used with.
    Gary
    • William H.
      • January 1, 2006
      • 213
      Thanks, Gary. Very helpful. Do you do replating in your business or just resell? Bill
      Bill Hyndman
      • Gary B.
        • February 1, 1997
        • 7064
        Bill,
        I don't do any replating.
        Gary
        • Gary B.
          • February 1, 1997
          • 7064
          Bill,
          I have a follow-up question for you. Where the majority of bumper bolts used in '68 plated zinc or cad? As opposed to natural or black phosphate?
          Gary
          • William H.
            • January 1, 2006
            • 213
            I'm by no means an expert but most of the bumper bolts I removed from my 68 were black phosphate. There were only 2 in the front that were zinc.
            Bill Hyndman
            • Gary B.
              • February 1, 1997
              • 7064
              Bill,
              In terms of plating, that's the reverse situation from the mid-year bumper bolts.
              Gary
              • William H.
                • January 1, 2006
                • 213
                Is it possible to have some fasteners not marked with a letter identifier of the manufacturer? I found some on the car without markings except for grade and thought they were original. I also found one's with NAT and wasn't sure if that was an original supplier. Thanks for your expertise.
                Bill Hyndman
                • Gary B.
                  • February 1, 1997
                  • 7064
                  Bill,
                  Yes, NAT is an original headmark, at least for '66 is was.
                  Regarding bolts with no headmark whatsoever, if you're talking about standard hex head bolts then off the top of my head I'm not aware of any such bolts for '66, although I'm not a headmark expert by any means. My guess is GM required headmarks on standard hex head bolts above a certain size at least for QA and traceability reasons in case a bolt on a structural part failed. But I'm sure others know more about this issue than I do.
                  Gary
                    Gary -
                    I'm not a headmark expert either, but this one is my favorite.
                    • Gary B.
                      • February 1, 1997
                      • 7064
                      John,
                      You have to thank your parents for that match.
                      Gary
