The good Old Days --- differential removal - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    Inaccessible or stubborn bolts ? Just drill access holes in the fiberglass. If you were real fussy, you might even patch later.
    Floorpan is currently on eBay. 2nd thumbnail is view from underside.
  • Brian M.
    • February 1, 1997
    • 1838
    Re: The good Old Days --- differential removal
    This method may be mentioned in the Chasis service manual.
    • Gene M.
      • April 1, 1985
      • 4232
      no need to ever do that (holes in floor). just remove the entire cross member, rear end and all. two 7/16 bolts on ends of member hold it in.
      • James B.
        • December 1, 1992
        • 281
        My 67 has a hole in the jack compartment behind the driver, maddening! I don't think it even saved bubba any time!
        • Dan B.
          • July 13, 2011
          • 545
          Exactly, and you have to pull up the carpet to make those holes?? That makes no sense.
          • Loren L.
            • April 30, 1976
            • 4104
            Wayne, holes can also be "markers"; two 1 1/4" holes in the lower passenger inner fender virtually confirm that the derelict you're looking at came with factory A/C and the two forward sparkplugs were changed by taking the wheel off....
            • John G.
              • January 1, 2004
              • 238
              With the rear cross member, leaf spring, rear cover, etc. in place on the car the diff carrier assembly can be removed/replaced as a separate unit if one chooses to do it that way. The upper two carrier bolts are somewhat difficult to reach, but doable.
              I just went through this. Not sure I'd do it this way again, though, without removing the entire rear end assembly.
