5spd in a 65 C2 - NCRS Discussion Boards
5spd in a 65 C2
+ More Options
Posts
  • Jim R.
    • June 30, 2001
    • 643
    5spd in a 65 C2
    Hi has anyone put one of the tremac 5spd kits in a 65 or any c2 and can it be done without pulling the motor(with ease) if anyone has could you let me know how it went and if you like it, my car has underneeth exhaust. thanks JR
  • Scott M.
    • January 1, 1996
    • 216
    Re: 5spd in a 65 C2
    Go over to the C2 Corvette forum, its a pretty common mod.
    • Stuart F.
      • August 31, 1996
      • 4676
      Re: 5spd in a 65 C2
      Jim;
      I've seen a number of articles about the swap and I know there are kits made for this. I believe the main problem some had with the earlier kits was driveshaft angular alignment and floor clearance on some model years (probably 63's). I'm sure you will get some advice fom others who have done the swap or know someone that has, and hopefully they have rectified the earlier problems with the installation kits.
      Stu Fox
      • Jim R.
        • June 30, 2001
        • 643
        Re: 5spd in a 65 C2
        Ok found plenty of info on the search button no more help needed thanks. JR
