Motor Oil for C3 - NCRS Discussion Boards
Motor Oil for C3
  • Tony L.
    Infrequent User
    • February 1, 1990
    • 19
    Motor Oil for C3
    Would like to know what others are using for engine oil. Having an car with very low miles, I change oil by time not mies. Recently had to replace cam, two worn lobes. Getting alot of advice, need some good advice. Thanks TL
  • Dick W.
    • 10483
    Re: Motor Oil for C3
    I think that if you search the archives, the consensus is to use a CJ-4 spec oil. There are many brands of oil that meet these specs, most of the time you will find it in 15W-40 weight. No need to use the fancy boutique motor oils when you can buy what you need at about any parts house, Walmart, or service station.
    Dick Whittington
    • Tony L.
      Infrequent User
      • February 1, 1990
      • 19
      Thanks Dick, I did review the archives after I posted. So, I shold be looking for a Cj-4 spec. What is your opinion on Rislone. I used to used a qt of it back in the 60's with my 442 and 396 Chevelle. 4 qts oil one qt Rislone. Thanks TL
      • Dick W.
        • 10483
        I used Rislone way back when, very dirty engines. Best I remember it caused more problems than it solved. I don't think with modern oils that you need any additives. Now fuel, that is another story....
        Dick Whittington
