65 396 intake manifold - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8385
    could you guys that have non-power brake 396's check the plug in the intake that would normally serve the power brake booster if PB equipped. my intake plug is an allen plug which just doesn't look kosher. i'd expect a pipe plug with four sides or a hex plug. thanks,mike
  • Dick W.
    • 10483
    Re: 65 396 intake manifold
    Square Doc
    Dick Whittington
    • Wayne M.
      • March 1, 1980
      • 6414
      Mike -- here's what's on a Feb 17 1965 cast manifold; notice the small raised "pimple" on the top of the pipe plug
      • Bill W.
        • March 1, 1980
        • 2000
        Mike ,#16120 has a square pipe plug . to rusty to tell if it had a dimple . My second one is open ....Bill
          • 43221
          Mike----
          I agree with the others. During the 50's, 60's, and 70's I can't think of a single application in which GM used an internal hex (allen) pipe plug. They were either external square head (by far, the most common) or internal square head.
          Incidentally, the most "egregious" use by GM of a square head pipe plug is for the external bypass fitting for 1972-82 Corvette small block waterpumps. What an ugly, non-factory-like installation for this so-very-prominent feature!!!!!! But, that's the way they were done. An internal hex head plug appears so much better. But, don't show up for judging with one.
          • Mike M.
            • May 31, 1974
            • 8385
            thanks much guys.mike
            • William D.
              • April 1, 1993
              • 101
              Mike - 21326 has a square one
              1965 Conv 327/365HP 4 sp, 3.73, KO's, pb 96.6 pts
              1965 Coupe fuelie, F40, 411's, teak/tele, 32K, 98 pts
              • Pancho T.
                • July 31, 1993
                • 238
                That is exactly what I have in my intake
                • Mike M.
                  • May 31, 1974
                  • 8385
                  i removed the allen plug and went to my drawer of pipe plugs and out of about fifty 5/8" four sided pipe plugs, i found one with a papule( a more correct way of describing the "pimple"). thanks much guys. mike
                  • Jaime G.
                    • April 1, 1988
                    • 480
                    21228 has a square plug w/papule
