'68 small block fan shroud - NCRS Discussion Boards
  • Brian W.
    • September 30, 1990
    • 216
    On a '68 350hp fan shroud there is a rubber edge stapled to the forward end. Do the staples go through the 2 layers of rubber and the metal or do they go through 1 layer of rubber and the metal? If 1 layer do the staples go from outside in or inside out?
    Brian
    • 43248
    Re: '68 small block fan shroud
    Brian
    Brian-----
    The staples went through the layers of rubber on both sides and the metal shroud. The staples were installed from the outside.
    • Brian W.
      • 216
      Thanks Joe.
