Black Plastic Panel - Need Help Identifing - NCRS Discussion Boards
  • Clark E.
    • March 1, 1991
    • 163
    The panel is approx. 10" x 4" and has a tab with a fastner hole at one end and a fastner hole at the other with a large U shaped cutout. There is a raise number 3956189 on the panel with an upper case B directly below it. I have no idea where it goes. As always, thanks. Clark
  • Bill C.
    • July 15, 2007
    • 904
    Re: Black Plastic Panel - Need Help Identifing
    only part I can think of is the panel that screws under the steering column.
    goes below the column and fills in the dash across the botom...
    PIC would be very helpful.
      • 43221
      Bill and Clark-----
      That's what it is. It's the dash panel mat cover applicable to 1969-72 Corvettes. It is shown on UPC 1, sheet D9 for 1969-72 Corvettes.
      • Clark E.
        • March 1, 1991
        • 163
        Thanks Bill and Joe. I found the illustration. The shop that replaced the windshield frame removed the dash without any documentation and as I re-install it, parts are showing up I haven't seen before. Are the two fasteners holding the cover panel rubber "plugs"?
