N03 Big Tank Identification Features - NCRS Discussion Boards
  • Tim S.
    • March 1, 1989
    • 124
    Are there any tell-tail signs that a big tank car would have after the 36 gallon tank and cover are removed?
    For instance is the rear shelf behind the seat the same height as as non-N03 Car? The car in question is a 1966
    Thank You
  • Dick W.
    • 10483
    Re: N03 Big Tank Identification Features
    Filled holes in the jack storage compartment and white inner fenders are two quick checks.
    Dick Whittington
      • May 31, 1974
      • 8409
      no3 partition between rear of car and the cockpit lacks the rectangular metal plate on its outside wall and there should be no evidence that the plate was removed and its rivet holes filled in. the rear 1/4's had their lips partially removed and the tubs were reworked at the factory. the main fuel line's route to the rear differs from base tank cars. the harness to the tank routes inside the car behind the drivers seat. i'm sure there are more but my feeble brain has been fading of late. but i'm still suckin air. mike
      • Wayne M.
        • March 1, 1980
        • 6414
        Here's an example of Dick's mention. Tanker is a '65 but shows the different (earlier) fiberglass fender panels. Assuming the car you're looking at (unlike this one ) is now painted, you can wipe the inner surface of the panel (via the wheelwell) to check.
        n
        • Tim S.
          • March 1, 1989
          • 124
          Thank you Mike...my feeble brain must be worse than yours! This is a race car so most things are "disturbed" , particularly the wire harness
          and it has a fuel cell so not sure about the fuel line clue. Unfortunately I am nowhere the car so no visual is possible. I understand the rear partition panel is removed but I am not sure what you mean about a metal plate on the outside wall? The rear inner fenders are white from Dick's clue.
          Tim
          • Tim S.
            • March 1, 1989
            • 124
            Thank you..my reply to Dick was incorrect I thought he ment the inside of the fender (inside the car) that I can see from a picture but the car is painted white so they may have sprayed the inside as well
            Thanks Tim
            • Wayne M.
              • March 1, 1980
              • 6414
              Originally posted by Tim Sargent (14767)
              ....This is a race car so most things are "disturbed" ... and it has a fuel cell ..... Unfortunately I am nowhere the car so no visual is possible, but I am not sure what you mean about a metal plate on the outside wall? The rear inner fenders are white from Dick's clue....
              Tim -- I'm guessing that this is what Mike meant by the rear vertical metal channel, riveted to the rear bulkhead with 6 rivets [see thumbnail below big pic]. On tankers, because of the fuel filler hole, [see big pic] they couldn't install this channel, so there should be no evidence of rivet holes in this panel on 36 gal cars; it's bare fiberglass, so easy to see.
              • Wayne M.
                • March 1, 1980
                • 6414
                Tim -- I hope we're not overloading you here, but here's one feature that is difficult to remove, and should show even if the car interior is carpeted (if you know what to look for).
                They're called the wheelwell filler panels, and the factory cuts out the standard inner fender cap and glues these on top, to give greater clearance for larger diameter tires (think 1963, '64 racing). They are fairly thick.
                First pic is view of the passenger side cap taken from perspective of driver seat. 2nd pic has the camera placed in the passenger rear corner, looking forward. That clip is the anchor for the jack retention spring. On the left you can see the tank cover bolted to the side channels, which are glued to the floor (tub). And on the right you can see the filler panel.
                There's more if (as previously referenced) there has ever been a fuel line from the pump to the standard 20 gal. tank. Two frame holes will show evidence of self-tapping bolts having been installed; and if it is an original 36 gal car, these two holes will show no thread marks and a 3rd hole will be drilled for the N03 fuel line routing.
                • Tim S.
                  • March 1, 1989
                  • 124
                  Wayne that is not overload I appreciate your photos ans explanations. I will have to ask the owner to take some more pics
                  Tim
                  • Gene L.
                    Infrequent User
                    • February 1, 1997
                    • 21
                    Thank You
                    I have just finished restoring an original (real) 1965 NO3. It would be easiest to discuss the differences over the phone. Cell # is 479-381-1039.
                    • Wayne M.
                      • March 1, 1980
                      • 6414
                      Tim -- just thought of another quick indicator. Ask seller to state what's on the '66 trim tag (under glove box). If upper RH is stamped A-xxxx (where x= a number 0 to 9, then it can't be an original big tank car]. Only St. Louis body line made them. In this case the upper RH will be stamped Sxxxx.
                      • James G.
                        • May 31, 1976
                        • 1556
                        TRIM TAG ''ecl'' code AB, CB, GB, JB, = N03 Tanks. for 1966 interior colors. I have other photos if you need more. Will have to dig them out and load them.
                        • Tim S.
                          • March 1, 1989
                          • 124
                          Jim
                          Thank you but this is a race car and no Trim Tag.
                          Tim
                          • James G.
                            • May 31, 1976
                            • 1556
                            Just sent you PM with photos Tim. I am happy to post here is all feel needed, but have to load photobucket first.
