Headlight assembly paint restoration question. - NCRS Discussion Boards
  • Joe M.
    • February 18, 2010
    • 83
    Headlight assembly paintrestoration question.
    I'm in the process of restoring a1973 headlight assembly and wanted to make sure I have the correct colors for judging. I painted the headlight housing support withKrylon Lacquer KO1613 Semi FlatBlack. What I'm looking for is what'sthe correct color of the headlight actuator bracket as I'm not able to find thecolor in the judging guide? If someonecould please point me in the right direction I would appreciate it.
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Headlight assembly paint restoration question.
    The head light actuator bracket is one and the same as the head light hsg support. Can you help me out here on just what you mean?
    • Dick W.
      • 10483
      If I understand correctly what you are talking about, it should be zinc chromate.
      Dick Whittington
      • Joe M.
        • February 18, 2010
        • 83
        I'll try and explain this usingpics of parts from Corvette Central as it will save time. The headlight housing support I've paintedwith withKrylon Lacquer KO1613 Semi Flat Black paint. Again for time sake this is headlight housing support is Corvette Central part number 443085L.
        My question is correct color for judgingon the headlight actuator bracket (Corvette Central P/N 443080). I've not purchased these parts from CorvetteCentral I'm just using the pics they have for an example.
        Thanks for your help
        • Bill W.
          • March 1, 1980
          • 2000
          Dick is correct . all under the header headlamp parts were painted green zink cromate with what ever overspray got through .They were not to picky. Bill
          • Joe M.
            • February 18, 2010
            • 83
            Thanks for the help, I appreciate it.
            Joe
            • Joe M.
              • February 18, 2010
              • 83
              Joe
