radiator date label - NCRS Discussion Boards
radiator date label
  • Roger B.
    • June 30, 1991
    • 82
    radiator date label
    Which radiator label is correct for 1962 build date april 62.
    metal or aluminum?
    thanks
    Roger
  • John F.
    • March 23, 2008
    • 2424
    Re: radiator date label
    Roger, My original Aug 61 build date radiator has an aluminum plate held by two very tiny screws.
    • Terry B.
      • December 6, 2010
      • 73
      Here are photos from my radiator, manufacture date stamped on the radiator is D 62 (April 1962). I believe the Harrison label is aluminum.
      • Mike E.
        • February 28, 1975
        • 5153
        Definitely foil. The date stamp by April was on the top of the left side of the radiator. When they used the metal tags (earlier) the date was on the tag, not on the radiator. The differentiation would not be metal vs. aluminum, rather metal vs. foil.
        • Roger B.
          • June 30, 1991
          • 82
          Mike, are there no dates on the aluminum tag?
          • Mike E.
            • February 28, 1975
            • 5153
            No dates on foil tag. Date is stamped on top of radiator left side.
            • Terry B.
              • December 6, 2010
              • 73
              Previously on this thread I posted a picture of a date stamp. I also posted a picture of the Harrison tag. I'm not sure I'd call the tag foil, I wouldn't necessarily call it a plate either. Guessing I'd say its maybe 1/100 of an inch thick.
              • John F.
                • March 23, 2008
                • 2424
                My thread above is the best picture I can get of my aluminum tag/plate with two tiny screws holding it on. It is not foil.
                • Mike E.
                  • February 28, 1975
                  • 5153
                  No, it's not foil, because it is the earlier metal/aluminum plate. The later tag was a much lighter material, configured much differently, with no date, no part number, and no screws.
                  • Terry B.
                    • December 6, 2010
                    • 73
                    My Harrison tag is much different from John's and does not have screws holding it in place. Mike is my tag what you refer to as foil?
