*** Job numbers on tank stickers *** - NCRS Discussion Boards
  • Blair K.
    • September 27, 2012
    • 170
    Can someone explain job #s found on tank stickers to me. I was told it starts at "1" and goes up to "500" and then starts at "1" again. Is this correct??? The job # is also written on the passenger footwell (exterior) Are there cases where the two job numbers (on the tank sticker and footwell) are out a couple of numbers from each other??? Thanks in advance.
  • Harry S.
    • July 31, 2002
    • 5293
    Re: *** Job numbers on tank stickers ***
    Originally posted by Blair Kaytar (55498)
    Can someone explain job #s found on tank stickers to me. I was told it starts at "1" and goes up to "500" and then starts at "1" again. Is this correct??? Yes, this is correct.
    The job # is also written on the passenger footwell (exterior) Are there cases where the two job numbers (on the tank sticker and footwell) are out a couple of numbers from each other??? I have never seen this. Does it look as if there were major repairs on the car? Meaning parts from different cars were put together to build this car? The Job number was written on the footwell, doors and behind the gas tank.
    Thanks in advance.
    My answers are in the quote
    • Stephen L.
      • May 31, 1984
      • 3156
      The numbers found on the various body panels go from 1-500 and repeat. These numbers appear to keep the various panels "together" during body assy.
      The number penciled on the tank sticker does not necessarily coordinate with the body panel numbers, but rather "follows" the final 3 digits of the VIN number, in many cases this number is within a couple of digits of the VIN. The penciled number also repeats every 500 numbers.
      Example: if your VIN ends in XXXX123 then the penciled number would typically be about XXXX120. If your VIN ends in XXXX623 then the penciled number would again be about XXXX120. [623-123=500 (repeat)]
      • Blair K.
        • 170
        Thanks gentlemen - much appreciated.
        Here's what I got:
        s/n S405338
        job # on tank sticker: 327
        # on footwell: 332
        Have a great weekend
        • Tom R.
          • June 30, 1993
          • 4099
          I'll assume that by your atar crossflag logo and Stephen's response, you're referring to the C2-early C3 period Corvette. By mid-70s this changed and a portion of the manifest schedule number was used as the three digit job number. By 81, when production was moved to Bowling Green, the job number reconciled with both the schedule number and the VIN last 3-4 digits.
          Tom Russo
          78 SA NCRS 5 Star Bowtie
          78 Pace Car L82 M21
          00 MY/TR/Conv
          • Blair K.
            • 170
            Now I am confused again. My early model '68 just has "327" (circled) on the tank sticker which I believe is the "job number". My tank sticker does not have two different numbers (last 2 digits of the s/n and job #)written on it like Alan's tank sticker shown above. HELP!!!!
            • Blair K.
              • 170
              I will check behind the gas tank - Where abouts does one check for the #'s on the inside on the doors. I was not aware of this. BK
              • Michael J.
                • January 27, 2009
                • 7118
                My late '67 build tank sticker only has one number penciled in (three digits), on the right side about 1/3 of the way down the sticker, and circled.
                • Blair K.
                  • 170
                  Just confirmed - "332" found on the body just in front of the gas tank - passenger side. Going to remove interior door panels to try to find numbers on the backside of fiberglass door skins.
                  • Blair K.
                    • 170
                    Same here, Michael. The consistency is there. Your late '67 build and my early '68. Thanks for the reply. BK
                    • Stephen L.
                      • May 31, 1984
                      • 3156
                      I can't speak to the double numbers.... as these are penciled notes from the assembly lines, I guess anything is possible for the workers to keep things straight.
                      On my 67 there was only 1 number penciled on the sticker. Other 67's I've seen are similiar.
                      Below are my tank sticker and body panels. My VIN # ends with "770"; therefore 269+500=769 or 1 digit before the VIN.
                      There is no reference to the job #416 on the tank sticker. WHY these numbers were penciled I do not know.
                      I believe the hood also carried the job number but was painted over during blackout. Maybe John Hinckley would have more info on this......
                      • Michael D.
                        • June 30, 1996
                        • 536
                        No need to remove your door panels; there will not be any numbers behind them. Check passenger's side tranny hump and see if you find 332.
                        Tranny hump position. 394 on this one:
                        • Blair K.
                          • 170
                          Thanks Michael for the reply and pics - much appreciated. You were right in regards to the doors - no numbers found. Although I found date codes on the door panels - driver side (Nov.20/1967) and passenger side - (Nov.10/1967) with the name of "Liz" in black crayon - GM assembly worker ???. Pretty cool. I do have "332" on the passenger side kick well but nothing on the transmission hump (as in your photo). I did notice on the passenger side transmission hump what looks like a section cut out and then "glassed" back in. Procedure shown on page H382 of the '68 AIM. M40 TH400 equipped car. Any thoughts on why this was done. Done on the assembly line (???). Thanks for your time.
                          • Michael D.
                            • June 30, 1996
                            • 536
                            The TH400 required the bump out in the floor. AIM shows where the tranny tunnel was cut and the bump out panel installed. Manual transmission cars do not have the bump out.
                            104 on this one, plus the TH400 bump out.
                            • William L.
                              • December 1, 1988
                              • 944
                              On my 23 June built 67 there are numbers on the doors.
                              Bill Lacy
                              1998 Indy Pacecar
