Mid-year, under-car exhaust question - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7053
    On a 2.5" under-car exhaust system on a mid-year, the front pipes are clamped to the rear pipes just forward of the center cross member. At that coupling location, is the diameter of the front pipe reduced in diameter to fit into the 2.5" OD rear pipe? Or is the rear pipe expanded in diameter to accept a 2.5" OD front pipe? In other words, which of those two pipes (front or rear) does not have a 2.5" OD? I'm guessing the front pipe has a reduced diameter, but I don't have an example to measure.
    Gary
    • 6950
    Re: Mid-year, under-car exhaust question
    Gary,starting in 64 the Mid pipe is expanded over the front pipe and in 63 it was to the front pipe was expanded over the mid pipe .The pipes were not reduced only expanded.
    • Russ S.
      • April 30, 1982
      • 2163
      The rear pipe has an increased diameter to slip over the front pipe.
      • Gary B.
        • February 1, 1997
        • 7053
        Russ,
        For '66, I know the front pipe slips inside the rear pipe. But I assume the pipe clamps are 2.5" clamps, which suggests to me the rear pipes must have an OD of 2.5", which in turn suggests that the ends of the front pipe are reduced.
        But you say the rear pipe is increased, presumably greater than 2.5'. Do you know the OD of the opening on the rear pipe?
        Gary
        • Russ S.
          • April 30, 1982
          • 2163
          Originally posted by Gary Beaupre (28818)
          Russ,
          Gary
          The rear pipe is expanded to 2.700
          • Gary B.
            • February 1, 1997
            • 7053
            Russ,
            Do you know for '63 and '64, was the OD of the pipe that was also 2.70"?
            Gary
            • Russ S.
              • April 30, 1982
              • 2163
              Russ,
              Gary
              Gary, I don't know on 63-64.
              • Gary B.
                • February 1, 1997
                • 7053
                Edward,
                Do you know the OD of the expanded end of the mid pipe for '64?
                Gary
                  • 6950
                  Gary if you would like a have a 63 CC exhaust on the floor in garage I can measure if you like.
                  • Gary B.
                    • February 1, 1997
                    • 7053
                    Yes, please. This morning I saw a CAD drawing for a nominal 2.5" exhaust clamp and the ID spec for the clamp is 2.67", so I suspect the OD of the pipe to be at that spec or maybe a few hundreds smaller.
                    Gary
                      • 6950
                      Gary, I took the measurement and the the front pipe expansion was 2.70 OD. and the mid pipe was 2.5 OD for my 63, I also took a look at the 63 center hanger clamp from center to center 3" inchs so I guess that the clamp for 63 had a little wiggle room. As I suspect the 64 up also had some.
                      Note the 64 up center hanger is different, The 63 center hanger is a one year only.
                      • Gary B.
                        • February 1, 1997
                        • 7053
                        Edward,
                        The CAD drawing for the clamp gives the center to center distance between legs of 2.94". Could your 3" measurement actually be 2.94"?
                        Gary
                        • Alan D.
                          • January 1, 2005
                          • 2046
                          For clamps also see Correct C2 Exhaust Clamp Vendor
                          Is the CAD drawing a GM and if so can I get a copy (or post here)
                          • Gary B.
                            • February 1, 1997
                            • 7053
                            Alan,
                            No, I have not seen a GM drawing. It's just something I found on the internet from one of the clamp companies. I have no way of knowing if the old GM specs are the same, but I assume there is some standardization in the clamp industry that has existed for decades.
                            Gary
                            • Alan D.
                              • January 1, 2005
                              • 2046
                              Thanks Gary, take a look at the above referenced old thread for some good pictures.
                              Note I use a 2 3/4 clamp which has a center to center measurement of 3.4" These go over the hanger and pipes - can be secured without leaving much of a dent in the pipes, however wrong size.
                              In that old thread I noted the nut for a production clamp does not appear to be the same as the N11 2 1/2 clamp since it is a nut with a flange & no lock washer, but have not been able to find any GM references to verify. The 2 1/2 GM clamps shown in the other thread certainly do have a different nut & lock washer.
                              Was able to find the 63 nut ( 102634 ) which is a Grade 286M, 17/64 thick with plain finish - it was discontinued without anything replacing it.
                              Have attached Some general GM clamps, note the C2's appear to use only the one's on the right.
