What is the correct color silver & or paint code for 1958 C1 Stock Rims? - NCRS Discussion Boards
  • Scott K.
    • September 30, 2010
    • 85
    Have reviewed forum to validate/confirm the correct color silver that would be used on a 1958 Corvette stock wheel.
    Can anyone advise if this is the same INCA silver metallic that would be found on a cove OR is it ARGENT SILVER OR is it some other Silver?
    Any brand & Paint Code Info appreciated.
    I did see the post that showed a semi-gloss black finish on the back with no overspray.
    Any information about that color & finish would also be appreciated.
    Thanks-
    Scott.
  • Terry D.
    • May 31, 1987
    • 2696
    Re: What is the correct color silver & or paint code for 1958 C1 Stock Rims?
    Scott
    C1's used the same paint as the body. Try www.autocolorlibrary.com
    • Philip P.
      • February 28, 2011
      • 558
      According to the 1958-60 Corvette Restoration guide(page 142) the wheels on 1958 all were silver. 1959 black, and 1960 body color. I think this is also what the Adams book says.
      Phil
      • Mike E.
        • February 28, 1975
        • 5141
        All 62 15x5 wheels with white walls were black, not body color.
          Originally posted by Terry Deusterman (11486)
          Scott
          Terry -
          The Paint Shop process notes from St. Louis (summarized below) state that the outer face of the wheels were sprayed with 83*-gloss wheel enamel, not body lacquer; the Corvette plant had no paint facilities for wheels or other raw metal parts - they were all processed at the main passenger/truck plant next door, racked, and delivered to the Corvette building.
          • Dan H.
            • July 31, 1977
            • 1369
            Hi Scott, just a hint, but if you spray your 58 rims with Krylon dull aluminum paint, they'll look great! Black semi gloss on backside with a little silver overspray showing through.
            Dan
            1964 Red FI Coupe, DUNTOV '09
            • Loren L.
              • April 30, 1976
              • 4104
              A tinge of disagreement with Dan - "flat black" will spray as a better approximation of black primer than semi-gloss. Just a note from Margaritaville.
              • Dan H.
                • July 31, 1977
                • 1369
                Must agree with Margaritaville, more on the flat side is fine!
