86 Corvette Park Lockout Cable, 4+3 - NCRS Discussion Boards
  • Nicholas K.
    Infrequent User
    • October 20, 2012
    • 4
    Hey guys I am working on an 1986 Vette 4+3 and the Park Lock Cable broke right at the shroud. Need help to find a new one and some help on removing the old one and installing a new one.
    Thanks!
    • 43258
    Re: 86 Corvette Park Lockout Cable, 4+3
    Thanks!
    Nicholas-----
    The part you seek was originally GM #14050072 and later GM #14076182. Unfortunately, the latter was discontinued without supercession in January, 1999. I doubt that a reproduction is available but it's possible as a few C4 parts are starting to be reproduced.
    I would say your best bet at this point is going to be good used. In that regard, a C4 used parts source like Steve Arcoleo in New York or Contemporary Corvette in PA could probably supply it. The cables from any 84-88 with 4+3 should work but I'd probably prefer one from an 85-88 which originally used the 14076182.
    • Nicholas K.
      Infrequent User
      • October 20, 2012
      • 4
      Thanks for the help guys and I do have the Y Carline Book! I was also wondering if they make any other parts for the steering column as well from these places since it does not seem like your average job.
        • 43258
        Nicholas-----
        If you mean are any steering column parts for 86 Corvettes still available from GM, the answer is that most are discontinued. There might be a few left, though. By "Y Carline Book" are you referring to a Parts and Accessories Catalog applicable to certain model year C4 Corvettes?
        • Nicholas K.
          Infrequent User
          • October 20, 2012
          • 4
          Okay I am looking at the cable and it is fine but now my problem has gotten a bit deeper. The cable back drive pin and spring are the problem. How do i get these 2 guys out since they are still stuck in the steering column. They seem to snap at the place in the worst place since I don't want to damage the column.
          Also I have the repair booklet which is named 1986 Corvette Shop Manual ST-387A-86​ as my guide.
