Does anyone have a picture of..... 350 small block heat and igniton - NCRS Discussion Boards
  • Roger D.
    • May 4, 2008
    • 301
    Does anyone have a picture(s) of a 350 small block engine (for 1972 Coupe) completey assembled on an engine stand that shows the heat and igniton sheilding installed?
    If so, can you post a few?
    I've seen a couple of poorly made drawings here and there but it would be nice to see an actual picture showing how all the pieces look installed.
    Thanks folks.
    Roger
    • 15633
    Re: Does anyone have a picture of..... 350 small block heat and igniton
    Thanks folks.
    Roger
    There is a drawing in the U69 section of your copy of the 1972 AIM that not only shows the shielding, but all the brackets and fasteners that hold it on. That is a lot more than you will see in a photograph or two or three.
      • 3418
      • Roger D.
        • May 4, 2008
        • 301
        Wow...you guys continue to come through with the answers!
        Terry, I had previously looked thru my AIM and thoroughly and never saw those. You made it real easy to find with the section number. Those are good drawings indeed.
        Alan thanks for the pictures. I had been having a hard time fiutting the LH Rear Ignition Shield. A picture is worth a thousand words!
        Regards
        Roger
          • 15633
          A lot of people go through just what you did Roger. Not at all the first or last time.
          Alan's pictures, as always, are just stunning.
          • Michael M.
            • November 1, 2004
            • 64
            Alan,
            The fuel pump plate on your 350 is painted orange. I was nicked 1 point for a painted plate at a regional meet in 2010 on my 71. While it is not stated in the judging manual page 72 section 13, should it be natural on 72's also? Comments welcome.
            Mike (42753)
              • 3418
              Hi Michael,
              Now the rest of the story.
              Those are 2 pictures I saved from another site a few years ago only as examples of the installed heat and ignition shielding which are so difficult to find. They're not my pictures or engine.
              I wouldn't expect the fuel pump plate to be painted engine orange since it was installed in St.Louis.
              Here's the engine I can own up to... and the plate.
              I'm sorry for the confusion!
              regards,
