1963 interior paint - NCRS Discussion Boards
1963 interior paint
  • Perry M.
    • January 1, 1977
    • 325
    1963 interior paint
    I've searched the archives and what I found only confused me further. Can someone please tell me what the glossness, or flatness, of the paint used for the dash side covers to the radio should be for a 1963? The color I am refering to is saddle tan. My covers seem to be too dark with too much metalic to be original. Do any venders sell a rattle can with the right shade and glossness for my needs?
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: 1963 interior paint
    Perry;
    I repainted mine back in about 1976 using spray can dye and they have held up fine ever since. My color, however, is dark blue. I still have a number of cans around as I bought a set of kick panel speakers and also did the complete headliner and window frames om my hardtop. As I recall, I just lightly sanded the panels and sprayed them.
    Stu fox
    • Harry S.
      • July 31, 2002
      • 5280
      Perry, I had the same problem with my 63 saddle interior. After buying some cans from the major parts suppliers I came across Tower Paint and Decorating. They are at P.O. Box 2345, Oshkosh, WI 54903. 920-235-6520.
      I called them and told them my problem. They said they had the formulas for the original lacquer paint. They said they would mix what I needed and place it in a spray can. It was $19.95 for the paint and $7.95 shipping. It turned out to be a perfect match, so I redid everything in the interior (radio side panels, steering column, kick panel strips, windshield trim, etc) except the dash as that was OK. The lacquer goes on very thin, so several coats were needed, no runs, no drips and no errors.
      This was in 2003. check to see if they are in business and give them a call. Let us know as I need to get another can. I need it to spray the jack tub and tool tub.
      • Perry M.
        • January 1, 1977
        • 325
        Thanks Harry. I will call them tomorrow. My car has different sheens of the saddle color. The doors and other fiberglass parts seem to be dull or flat while the windshield moldings and halo parts are glossy.Stuart, I looked at the spray dyes from Corvette Central. I might talk to them as well.Thanks, Perry
        • Rob M.
          NCRS IT Developer
          • January 1, 2004
          • 12722
          Let me know if it works out, I need the same paint color (we might be able to get some discount to get more than one can prepared)?
          regards,
          Rob.
          Rob.
          NCRS Software Developer
          • Paul Y.
            • September 30, 1982
            • 570
            regards,
            Rob.
            I also need the same saddle tan color. am open to a discount Paul
            It's a good life!
            • Wayne M.
              • March 1, 1980
              • 6414
              Perry --- from Oct 1962 issue of Chevrolet Service News (introducing the 1963 features), they list the Refinish Paint Chart, a column of which covers Corvette. There are two "Medium Saddle" codes; one for the rear window garnish & halo panel (only) [Non-Metallic] -- Dupont 95243 and RM 62C87 (both of these are furnished in high gloss only and will need added flattening. The third paint supplier, Ditzler, code DL-22299 apparently needs no flattening agent.
              We have to assume that all other medium saddle interior parts (ie. 36 gal tank covers ) use Dupont 95355; RM 62C82 (both need flattening) or Ditzler DL-22298 (no flattening).
              In 1965, there were several different formulas and gloss levels, and for Ditzler, on the back of their color chip chart, they say which goes where. Example: Low gloss "Medium Dark Saddle" on Instrument Panel, Windshield Lower Garnish, Radio Speaker Screen, Heater Outlet Panel, Seat and Jack Stowage Wells.
              Low gloss black on Directional signal housing, Mast jacket, Steering wheel hub, steering column escutcheon, Glove box frame, linkage cover panel inner (not sure what that one is).
              Another paint code of medium saddle was used on Headliner, Rear compartment inner area, linkage cover panel outer (?)
              Full gloss used on: Windshield side and upper garnish mounlings; upper garnish mouldings; halo panel; Hardtop garnish mouldings; door upper -- inner; kick panel retainer; lock pillar return flange and cap (inner) [?]
              I had a '65 white/saddle convertible (back in 1968) and I'd swear that there were about 5 different shades / glosses on the various parts.
              • Perry M.
                • January 1, 1977
                • 325
                Thanks Wayne. That's the information I needed. In the meantime Tower paint is supposed to get back to me.
                Wayne, I sent you a PM yesterday regarding another matter.
                • Perry M.
                  • January 1, 1977
                  • 325
                  I got ahold of Tower Paint on Monday. A nice lady by the name of Chris said she would look into the matter of mixing the Saddle Tan paint in lacquer for me. She called me back yesterday and said she could still do it. After talking with her for some time, it turns out she has the same formula that Wayne described in his post. There are two Diztler formulas, DL22299 and DL22298. The price went up to 21.95 plus shipping with no multiple order discounts other than for shipping. Since I had her on the phone and the fact that she was very helpful, I ordered 1 spray can. I know I could have gone to my local PPG paint supplier and had the same paint mixed there but I also know it would probably cost more. I recently had 1 pint of Ermine White paint mixed in acrylic laquer at a cost of $109. Ouch. Would have been $800+ for a gallon.
                  • Harry S.
                    • July 31, 2002
                    • 5280
                    I just ordered one of each, I have some touchup to do everywhere.
                    • Rob M.
                      NCRS IT Developer
                      • January 1, 2004
                      • 12722
                      Do you have contact details so I can inquire to ship a can to the Netherlands?
                      Rob.
                      • Harry S.
                        • July 31, 2002
                        • 5280
                        Look at post #3 and ask for Chris when they answer. I told Chris you might be calling. Order enough to make it worth the shipping.
                        Cheers
                        • Perry M.
                          • January 1, 1977
                          • 325
                          Tower Paint --- 1-800-779-6520
                          • Sydney G.
                            • February 1, 1994
                            • 443
                            I just ordered the same Harry. I've been wanting to fix up my speaker grill for 20 years along with many other areas.
                            Syd
                            • Joseph S.
                              National Judging Chairman
                              • March 1, 1985
                              • 851
                              Guys, Last year I finished up a restoration on a very original 63 Coupe with Saddle Tan interior. The car never left the family. I can tell you for certain that there were 2 completely different colors for the painted trim. None of those colors were the "Vinyl Dye" colors you can buy from the Corvette suppliers. I don't remember if it was a difference in color between the fiberglass parts and steel parts or if it was a difference in color depending on where the part was in the car. I do remember that the Radio side panels and the speaker grille were darker than the trim around the rear windows. I will have the car back in the shop in the spring but it is too far away right now to take a look. I may have more photos.
