foam pad placement - NCRS Discussion Boards
foam pad placement
  • Joseph P.
    • September 7, 2009
    • 138
    foam pad placement
    I just got my spare tire board and wanted to make sure that I glue down the 3 foam pads in the right place. Also can I use the same glue as the label; a yellow glue and do I spread it out excessively like they say to do with the label ? I bought the yellow glue at Staples that is used to glue paper, etc. I tried to go to the archives but I don't believe I was wording it correctly to get help. Thank you. Joe
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11370
    Re: foam pad placement
    Joe, try this in your search parameters.
    spare AND glue AND board
    It gave 8 previous threads with some pictures of originals.
    Rich
    • John F.
      • March 23, 2008
      • 2427
      Joe, not sure about the glue, but it is slopped on my original.
      John
      • Joseph P.
        • September 7, 2009
        • 138
        Thanks guys for your info and the pics. I looked high and low to find some pics or drawings but no luck. Garbage in garbage out.
        • Troy P.
          • February 1, 1989
          • 1284
          • Mike E.
            • February 28, 1975
            • 5153
            John's 62 is more typical. Apparently they were more careful in 54. Or had more time on the line to do that. Or it was done by a careless worker. Or........
            • Joseph P.
              • September 7, 2009
              • 138
              What a big difference! I guess in 54 the corvette was still pretty hot stuff so they took more care with the pads. However I saw an original 53 and the exterior finish looked a little rough. I think in 62 they transfered the exterior guy to putting on the foam pads. LOL. Joe Thanks guys.
