62 clutch fork replacement - NCRS Discussion Boards
  • Edward H.
    • May 31, 2005
    • 24
    Doing a body off on my 62 360FI. Now in final assembly. When I installed the clutch/brake pedals and tried to adjust the clutch, I found the fork had come off the retaining pall and clip (riveted to fork) was broken. The fork almost can be remopved through the boot hole, but, not quite. Before I drop the trans and bell houising, I wanted confirmation that that is the only way to replace the fork. Thanks Ed
  • Mike E.
    • February 28, 1975
    • 5153
    Re: 62 clutch fork replacement
    My experience has been that you're facing tranny and bell removal. I haven't found a shortcut.
    • Mark S.
      • July 31, 1983
      • 668
      Rev Mike: Do you still have the FI filter wrench that I sent to you? Thanks, Mark
