I am trying to restore a 1966 coup with AC.
There are two holes in the firewall. One is well visualized in the AIM (C60, E5 pg. F291) with a four hole configuration for the grommet. the holes seem to be for the Engine harness, oil pressure line, and two air lines. That picture also suggests that the AC harness goes thru the same hole as the engine harness. I don't see how this could possibly fit. there is a second hole in the firewall with a second grommet with two hole in it. this hole is on the slanted part of the firewall near the windshield washer motor. Could this be where the AC harness passes thru the firewall?
Just cant see how I can get both harnesses thru that one hole in the 4 hole grommet.
Does it really matter?
Thanks for the help.
Joe
Joe
