Changing Dash Bulbs on 67 - NCRS Discussion Boards
  • Al P.
    • February 15, 2011
    • 87
    I need to replace the bulbs in my 67 Dash Cluster. Everything else is fine and everything works fine. Can I just pull the dash cluster out a bit to replace the bulbs?
    I don't want or plan to pull the column out. How far can I pull the cluster forward on long threaded rods in place of the 5 dash mounting screws?
    Will I be able to get to the bulbs?
    Thanks All!
  • Michael H.
    • December 1, 1987
    • 733
    Re: Changing Dash Bulbs on 67
    Yes you can but you'll have to drop the column down but not out. Get five 4" or 5" long 1/4-20 bolts that will help support the cluster as your reaching behind it change the bulbs.
    Mike
    • Kenneth B.
      • August 31, 1984
      • 2091
      Thanks All!
      Some you can change without pulling the cluster. I replaced my speedometer bulb but it was not easy.
      • Paul J.
        • September 9, 2008
        • 2091
        Mike
        You can also support the cluster by resting it on a stack of wooden blocks. However, I've even changed the headlight warning bulb without removing the cluster...patience, patience.
        Paul
