size of drill bit & tap for crank snout - NCRS Discussion Boards
  • Al R.
    • June 30, 1988
    • 688
    Hi All, I've searched the archives w/o success. What size drill bit & tap does one use to tap & thread the crank snout for the balancer bolt? Also, any helpful tips would be appreciated. Engine is out of the car and on an engine stand, so access is easy. TIA Al
  • Doug F.
    • November 1, 1983
    • 322
    Re: size of drill bit & tap for crank snout
    we use 7/16 x 20 bolts in our cranks so the tap size we use is 25/64 ths, make sure you get the hole drilled straight or you will not be happy with the results
      • 43272
      Doug-----
      With the crank installed in the engine, getting the hole drilled straight is tough. However, getting it TAPPED straight is even much more difficult.
      • Al R.
        • June 30, 1988
        • 688
        anyone ever made a type of homemade jig to help keep the bit straight??
          Al -
          Note that it's 7/16"-20 for small-blocks, and 1/2"-20 for big-blocks; 1/2"-20 takes a 29/64" tap drill.
          • Al R.
            • June 30, 1988
            • 688
            Thanks John, any tips on keeping proper alignment. I've thought about putting a level across the top of the block to level long ways, but unsure how to keep the drill level
            • Clem Z.
              • January 1, 2006
              • 9427
              if you have a friend with a machine shop have him make you a drill jig to slip fit over the crank snout with a pilot hole on the end to align the drill and then the tap
                • 43272
                clem-----
                That's a great idea. The tool could be modeled after and, perhaps, partially fabricated from one of those crank turning tools which slip over the crank snout.
                • Clem Z.
                  • January 1, 2006
                  • 9427
                  make a drill jig like this.
                  • Al R.
                    • June 30, 1988
                    • 688
                    Thanks all for the responses. I'll try to contact a machine shop on the suggestions.
                    • Bill H.
                      • August 8, 2011
                      • 439
                      My Ryobi drill has levels built into the top of it.
                      I do like Clem's jig and realize that you need to protect the crank but if it was me. I'd use an easyout, PB Blaster and some heat. Just did 3 bolts on my 67 this way yesterday.
                      And, if you can pull out the broken piece, i wouldn't use a thread tap, I use a rethread "tap".
                      But do it the way that makes you feel comfortable.
                      • Clem Z.
                        • January 1, 2006
                        • 9427
                        i was under the impression he was starting with a undrilled crank
                        • Bill H.
                          • August 8, 2011
                          • 439
                          Proly, my mistake Clem.
                          • Thomas N.
                            • July 31, 2002
                            • 405
                            I made one of these tap guides to clean out a broken crank snout bolt for a neighbor in his sbc. I'm pretty sure I've got it in my toolbox. If you are interested, I can find it and drop it in the mail to you.
                            NCRS New England Chapter Chairman 2022, 2024
                            N E Regional Chairman 2024
                            1967 Corvette Convertible Under Restoration
                            1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
                            • Al R.
                              • June 30, 1988
                              • 688
                              Thanks anyway Thomas, someone is sending me one to use and return. Appreciate the offer, though. Al
