Odd stamping on 66 frame - NCRS Discussion Boards
  • Lawrence S.
    • April 1, 1993
    • 807
    Tonight I saw a 66 small block frame that had a stamped 10 with a stamped circle around it. This stamping was on the underside of the frame drivers side in front of the second cross member. I was wandering if this was a repo frame? It was very nice looking frame, and on a top flight car. Sound familiar?
  • Michael G.
    • January 1, 1997
    • 1251
    Re: Odd stamping on 66 frame
    Lawrence,
    Have seen the stamping several times on factory frames. I understand no one seems to know what is meant by stamping.....factory frame however.
    • Mike E.
      • June 24, 2012
      • 920
      You should also see the symbol on each side of the corner gussets on the 3rd crossmember.
      Mike
      • Ray G.
        • May 31, 1986
        • 1189
        Anyone have an image of this "circled 10" stamping ?
        Thanks.
        Ray
        I hope you dance
        • Lawrence S.
          • April 1, 1993
          • 807
          Thanks good info
          • Thomas N.
            • July 31, 2002
            • 408
            Hi:
            Enclosed is a picture of the circle 10 stamping on the corner gusset. I have a thread open that shows other stampings and such on my current restoration.
            NCRS New England Chapter Chairman 2022, 2024
            N E Regional Chairman 2024
            1967 Corvette Convertible Under Restoration
            1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
            • Richard E.
              • April 30, 1992
              • 190
              My 67 has the same stamping.........
              • Bill H.
                • August 8, 2011
                • 439
                Yea, mine too.
                • Bruce B.
                  • May 31, 1996
                  • 2930
                  From what I have just read is it possible that the stamp is some sort of a weld inspection stamp?
                  It seems to appear near frame weld areas.
                  Just a thought.
                  • Scott S.
                    • September 11, 2009
                    • 1961
                    Originally posted by Bill Hetzel (53669)
                    Yea, mine too.
                    Mine three (on '67 frame)
                      • 15646
                      I have seen it on early C3 frames.
                      • Peter H.
                        • April 1, 1980
                        • 231
                        My 63 has a factory frame supposed to be the last one @ gm oshawa ontario.. Purchase in 1975 .. It has the same stamps...
