67 400 HP A/C PS PB 4-speed - NCRS Discussion Boards
  • Michael S.
    • April 1, 1990
    • 68
    Could someone please post a photo of the face of a correct Eaton fan clutch for very early 67 (Nov 66) car? My car is a convertible 400 hp, 4-speed with A/C, PS, and PB. Or at least tell me what the correct stamping should be? I have tried to search the old posts but I have not found the answer.
    Mike
    Re: 67 400 HP A/C PS PB 4-speed
    Mike
    Mike -
    An original Eaton '67 big-block fan clutch looks like the photo below; note the squared-off reservoirs and the "CK" ink stamping. The ink date stamp would be in the MDDY format, where "A" is January for "M", then the day(s), then "G" for 1966 or "H" for 1967.
    • Michael S.
      • April 1, 1990
      • 68
      John,
      That is exactly what I wanted to see. Thanks so much. I tried to copy the photo to enlarge it but I was not able to do that either. Would you mind sending the photos to me at: michael.sabrsula@comcast.net
      Mike
        John,
        Mike
        Mike -
        If you click on the thumbnail, it should enlarge, then if you right-click the enlarged image, you should get a drop-down menu to save it. If that doesn't work, let me know and I'll send it to you.
        • Michael S.
          • April 1, 1990
          • 68
          John,
          I did that but when I try to get the picture large enough to see some detail, it has too much distortion.
          Mike
            John,
            Mike
            Mike -
            You have mail.
            • Michael S.
              • April 1, 1990
              • 68
              John,
              Thanks, I'll have to chck it when I get home tonight.
              Mike
              • Michael S.
                • April 1, 1990
                • 68
                John,
                I can see them now. Thank you very much. That's exactly what I needed.
                Mike
