62 fuel line - NCRS Discussion Boards
62 fuel line
  • Robert K.
    • July 31, 1984
    • 213
    62 fuel line
    Well my 50 year old fuel line broke when touched at the fuel pump. Tested the fuel pump and it is fine as is the line to the carb. So I believe I have a small leak in the fuel line between the pump and the tank. Is there any other rubber line in the rear, near the tank, or is it a rusted steel line?
    I found it, it looks like at least 2 pieces of rubber hose back by the tank.
  • John F.
    • March 23, 2008
    • 2415
    Re: 62 fuel line
    There is rubber vent hose line as well as two sections of line from the sender thru the body to the main line and then a short setion just before the fuel pump. I replaced all pieces after finding crud in the fuel filter in the carb as well as in the fuel pump. The line to the fuel pump broke in my hand when I went to take out the fuel pump. Of course it was 50 years old. Hope these pics help.
    • Robert K.
      • July 31, 1984
      • 213
      Re: 62 fuel line
      Perfect and thanks
