67 327 Fuel Pump - NCRS Discussion Boards
67 327 Fuel Pump
  • Al R.
    • June 30, 1988
    • 687
    67 327 Fuel Pump
    Did the original 67 40433 fuel pump for a 327-300HP engine have both the inlet & outlet female threaded for a fitting or was it just the outlet that was threaded for the pipe that went up to the carb? The replacement that was on my car had a nipple piece that was part of the lower section, that the rubber hose from the tank line attached to. The "correct rebuilt 40433 pump" that C-Central shows has the 2 female threaded fittings on it (CC Part #352245) . I just want to get the correct type the 1st time. TIA
  • Al R.
    • June 30, 1988
    • 687
    Re: 67 327 Fuel Pump
    Never mind! Just found a previous post that answered my question.
