Trailing arm shims - NCRS Discussion Boards
Trailing arm shims
  • John W.
    • January 31, 2006
    • 16
    Trailing arm shims
    Re-assembling the rear suspension on my 72 coupe. Question is about best way to shim the trailing arms. I kept the original shims in order when I disassembled - likely the factory setup. Should I go back with the same setup, or is there a better way to get as close as possible without an alignment machine?
    • January 31, 1988
    • 43194
    Re: Trailing arm shims
    John-----
    What you are doing is the best way to go. However, you should still get a four wheel alignment performed after the car is back on the road.
    • Kurt G.
      • April 30, 2005
      • 343
      Go back the same way you took them off. Did mine last winter, went back as they came off and when I took it for alignment all the guy had to do was make sure everything was tight.
      Kurt Geis
      Chairman, Midway USA Chapter
      Targa Blue 1972, Top Flight and Duntov Award, 2014
      Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
      Arctic White 2013 60th Anniv Special Edition Conv.
