On my 57 Corvette Gasser project I am making 1 modern improvement and that is using a dual master cylinder with a GM combination proportioning valve.
I have Airheart disc brakes on the front and Olds drum brakes on the back.
I questioned one of the big aftermarket brake system suppliers about using DOT 5 in the system.
He told me DOT 5 is not good for the whole brake system and it would swell the rubber components in the master and wheel cylinders and that DOT 5 fluid is junk.
I respected his opinion until he said the DOT 5 was junk.
I have used DOT 5 in my 57 and my 62 and never had any rubber swell or general brake problems.
Both systems were rebuilt with what I would call regular off the shelf rebuild kits which I would guess use modern polymers which I would think are also used in the upgraded system.
I obviously do not want to risk brake failure, but on the other hand I think DOT 5 fluid is superior to DOT 3 and 4.
Any opinions would be appreciated.
