C1 Harmonic balancer rebuild question - NCRS Discussion Boards
  • Arthur T.
    • June 30, 2006
    • 34
    My '58 harmonic balancer needs a rebuild. I have the original 584 balancer. It needs blasting an painting. The rubbers need to be replaced.
    Two questions : These were semi-gloss when new. Does anyone have a good approximation of the black paint that should be used to refinish this part?
    The rubber and rivets are available from Paragon. Does anyone have any idea how to replicate the "waffle" riveting tool used to rivet this assembly?
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: C1 Harmonic balancer rebuild question
    You need to send the balancer out to a rebuilder. The rubber is not available as a replacement part, it has to be replaced by a professional.
    A good rebuilder may be able to replicate the pattern on the rivet heads
    • Arthur T.
      • June 30, 2006
      • 34
      Paragon sells the rubber and the rivets as a kit. I do not know how accurate these parts are, having not seen them in person. Paragon also offers a rebuild service. Again, not having seen one of their rebuilds, I cannot offer any opinions about the quality or fidelity of their work. Informed opinions of this sort are welcome. The names of competing rebuilders are welcome as well.
      That being said, I have the tools to rebuild the part myself, except for the unusual upsetter with the waffle pattern. Any comment from a rebuilder about how to do it properly would be welcome.
      • Donald H.
        • November 2, 2009
        • 2589
        I bought the kit and rebuilt my balancer for my 1960. The key is having a press. I have a 20 ton press and it was no problem. The rivets have a step or shoulder stop that sets the depth for pressing so that you don't over-squeeze the rubber. The hardest thing is peening the rivets. I tried an rivet air hammer, but I ending up doing most of it with by hand with a ball peen hammer. I did not try to replicate the hash markings on the rivets.
        Don
        Don Harris
        Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
        • Arthur T.
          • June 30, 2006
          • 34
          Don
          Don,
          Thanks for your reply. I have a 20 ton press, sandblast cabinet, etc. My balancer has a lot of rust on it.
          Did you refinish the two wheels of your '60 balancer? If so, what kind of finish did you apply?
          NCRS judging guide says the balancer was painted with the engine assembly, implying that it should be Chevrolet engine orange. I do not think this is correct. I am 100% certain my balancer is original and the portions of it that are not rusty are semi-gloss black, similar to the fan belt pulley that was bolted to it. The timing notch was highlighted in white at some point, though I question how original that bit is.
          Thanks again,
          Art
            Art -
            The JG is correct - the balancer was installed on the engine prior to painting at Flint V-8, along with the early riveted-on crank pulleys; photo below was taken on the Flint V-8 shipping dock in 1955. The later bolted-on crank pulleys were installed at St. Louis, and were flow-coat primed semi-gloss black.
            • Joe M.
              • April 30, 1990
              • 1342
              Donald, on your 60, is the harmonic balancer large wheel solid or does it have holes around the perimeter (flat face) of it? Apparently mine was rebuilt some time in the past and the original was replaced with one that has holes. Flight judge informed me that it should not have holes around the perimeter of the large wheel.
              • Donald H.
                • November 2, 2009
                • 2589
                Don,
                Thanks again,
                Art
                I painted mine with self etching black primer after I cleaned up the parts, then put it together and painted with engine orange paint.
                Don Harris
                • Donald H.
                  • November 2, 2009
                  • 2589
                  Mine looks like the one on page 74 of the TIM & JG. No holes in the outer ring.
                  Don Harris
                  • Arthur T.
                    • June 30, 2006
                    • 34
                    Art -
                    [ATTACH=CONFIG]42478[/ATTACH]
                    John,
                    Do you know what sort of upsetter GM used to set the rivets in these early harmonic balancers? The rivet tails on the low horsepower balancer face forward and an energetic judge with a flashlight who might be looking for extra holes in the outer wheel of the balancer can see them. I'd like them to look similar enough to the original 'waffle' shop heads to pass muster.
                    Art
                      John,
                      Art
                      Art -
                      No, I don't - the balancers were made by outside suppliers. The two outfits in Redding, CA that have been rebuilding them for years probably know.
