1968 Corvette Console "Insulation" - NCRS Discussion Boards
  • Bob S.
    • May 31, 1986
    • 254
    Removing the Front , EB Console & Shift Plate, I've found a lot insulation, (for lack of a better term.) It's not uniform in it's application, so I'm ASS Uming it's from work that has been done before I owned the car.
    What would be a good replacement?
    Bob DeSimone
    (9944)
  • Russ T.
    • May 31, 1989
    • 113
    Re: 1968 Corvette Console "Insulation"
    Bob:
    I went to a carpet store and bought some of that carpet underlayment
    that's sort of a blanket of carpet remnants glued together.
    It's inexpensive, too. You may want to try it.
    Russ Trotter
    NCRS # 15044
    • Bob S.
      • May 31, 1986
      • 254
      Originally posted by Russ Trotter (15044)
      Bob:
      NCRS # 15044
      Thanks, Russ
      I just ordered new carpet, and noticed that they offered a "Box" of Sound Deadner/Heat Shield remnants for 30.00...actually, buy one get one free. I ordered them. Think that would do the trick?
      Bob DeSimone
      (9944)
        • 3418
        Hi Bob,
        The insulation pieces on the transmission tunnel are the same material as was applied to the very top of the cowl on the interior side.
        It's what I would describe as 'jute', it's quite rough, shaggy, and loose. I believe there were originally 4 pieces on the tunnel; mainly under the shifter console and the e-brake console. They appear to have been die-cut but then torn some too in order to place them. There was a little bit of glue holding them in place.
        I have tried to find a source for material that looks like this but haven't yet found one. It's similar to the jute padding on the carpet but much less dense and much more 'scraggily'.
        Can you re-use what you have... might it be the original.... does the originality matter to you?
        I'm posting a couple of pictures in hope that someone may see them, and suggest a source for this material.
        • Don L.
          • August 31, 2005
          • 1006
          Alan, having worked in the automotive interiors business for 20+ years, I know that material as "Shoddy Pad". You can Google the term for some leads.
          How thick is your material? I will reach out to a few interiors colleagues and see if I can get some potential supply leads.
          Don Lowe
          NCRS #44382
          Carolinas Chapter
            • 3418
            Hi Don,
            Well that's certainly an apt name.
            It's a little hard to judge the thickness because it appears where it was die-cut the pad was permanently compressed to 1/4" to 3/8" thickness but in other areas... really most of it.... it measures 5/8" to 3/4". And, as I said, the material in those areas is very loose.
            A lead on a source would be great!
            • Bob S.
              • May 31, 1986
              • 254
              Hi Bob,
              That looks to be the stuff, but mine is even more "Scraggly". Probably from someone before me being in there. No, not concerned about what I replace it with. What's in there now is glued down like you say. The stuff I ordered is jute backing with the silver covering for heat dispersion. I may just use the jute. I don't have that much to replace and will keep what's already in there.
              Who knows, maybe the guys in the plant in 68 only put that much in!??
              Bob DeSimone
              (9944)
              • Michael D.
                • June 30, 1996
                • 536
                Originally posted by Bob De Simone (9944)
                ...found a lot insulation...so I'm ASS Uming it's from work that has been done before I owned the car...
                Some of what you found is probably stock. The AIM shows a couple or three pieces of underbody insulation for the console and e-brake areas.
                • Bob S.
                  • May 31, 1986
                  • 254
                  Just found this at Zip Corvette....This might be the stuff http://www.zip-corvette.com/ProductD...=68-75+Interio
                  Bob DeSimone
                  (9944)
                  • Bob S.
                    • May 31, 1986
                    • 254
                    Just found this at Zip Corvette...might be the stuff...or reasonable replacement http://www.zip-corvette.com/ProductD...=68-75+Interio
                    Bob Desimone
                    (9944)
                    • Bob S.
                      • May 31, 1986
                      • 254
                      Hi Bob,
                      Just found this at Zip Corvette. Might be a good alternative??? http://www.zip-corvette.com/ProductD...=68-75+Interio
                      Bob DeSimone
                      (9944)
