1969 hardtop question - NCRS Discussion Boards
  • Douglas C.
    • August 31, 1990
    • 384
    Hi all. Looking at an e-bay hardtop, seller says for a 69.
    My car was built Jan. 69 and has on the windshield center / top the steel pad for the center latch, and my convertible top has a center latch lever.
    The hardtop on e-bay has the 3 front latches that would match my car, and just the two outer rear connections which is also how my car is.
    He gave me rear glass codes of:
    DOT 15
    M52
    AS2
    I cannot find what a M52 would designate in my reading, can someone help me here to determine if this e-bay hardtop is correct for my car?
    Doug
  • Ralph S.
    • February 1, 1985
    • 935
    Re: 1969 hardtop question
    There is a 2 letter code for the date right next to those numbers you posted.
    • Paul L.
      • November 1, 2002
      • 1414
      Do you believe that a hardtop adds value to your 1969? I am reallly betwixt and between on buying one.
      • Terry B.
        • August 31, 1999
        • 607
        Hi Paul,
        It would be good to have the correct date coded hardtop if you could get it at a reasonable price and didn't have to make costly repairs but it will most likely stay in your storage area much longer than ever on your car.
        Terry Buchanan
        Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
        Corvettes Owned:
        1977 Coupe
        1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
        2003 Electron Blue Coupe
        2019 Torch Red Grand Sport Coupe
        • Douglas C.
          • August 31, 1990
          • 384
          Originally posted by Terry Buchanan (32872)
          Hi Paul,
          Yes, agreed. But, if I can find the right one at a good deal I would get it. And I really like the look of the hardtop on the 69's, I would use it in the winter when the weather was clear (yes, I said that, but I've lied before) .
          Thanks, Doug
          • Paul L.
            • November 1, 2002
            • 1414
            Hi Paul,
            I fear that that would be its fate. I did commit to one last week but have now backed off. So it is soft top still. I do not drive in winter and in fact my 1974 is now in winter commercial storage until April. Its a "nice to have" but the cost estimates to paint or cover in black vinyl were pretty staggering.
            My local GM dealer would not even consider removing the SS trim or the rear window. Too much potential for damage. They wanted to do the old MAACO trick and just tape around things?? And that was $750.00.
            • Robert R.
              • May 31, 1975
              • 358
              Paul,
              Sorry to hear that you did not get the hardtop.
              I do use mine from time to time, just for a different look. When on, I do get a bit more headroom than when the ragtop is up. Obviously, the best is when the top is down.
              Bob
              • Paul L.
                • November 1, 2002
                • 1414
                Originally posted by Robert Ricchio (599)
                Paul,
                Bob
                I put my soft top down in May and back up in September. That is my driving season in Canada. I do avoid rainy days if possible. And I normally do. So my use of a hardtop would be minimal. But they sure do look nice. I was very tempted. But not for the price.
                • Dale C.
                  • November 1, 1999
                  • 844
                  Where are the date codes and the numbers on the tops so as to verify the top? Are they the same for 68? Without removing the panels you can check the date code on the glass.
                  Dale
                  • Terry B.
                    • August 31, 1999
                    • 607
                    Hi Dale,
                    On the convertible top, the date code is located on the driver side plastic rear window. It will read month and year. Example 1067 is October of 1967. On the Hardtop it will be 2 letters on the rear glass near the logo. Example AZ is A = September Z = 1967.
                    I hope this helps.
                    Terry Buchanan
                    Corvettes Owned:
                    1977 Coupe
                    • Dale C.
                      • November 1, 1999
                      • 844
                      Thanks, That is what I thought. You use the glass code so mine is VZ, which would be Dec 1967. There are no other dates on the hard top?.
                      Dale
                      • Terry B.
                        • August 31, 1999
                        • 607
                        Dale,
                        There are no other dates on the hardtop or soft top that are judged. Just the glass on the hardtop and the rear window on the convertible top.
                        Terry Buchanan
                        Corvettes Owned:
                        1977 Coupe
